Einleitung
This guide will go through the steps necessary to remove the power supply unit from the PlayStation 4 Pro. Some disassembly is required for this removal, but it is one of the first things that can be removed from the PS4 Pro.
Begin by flipping the console upside down.
Use your finger to pull and snap off the plastic cover over the hard drive.
Use a screwdriver to remove the single Phillips #0 screw securing the hard drive caddy.
Pull the hard drive caddy straight out.
Flip the console right side up.
Grip the two corners located at the front of the device.
Pull upwards until a loud click is heard.
After both corners detach, slide the cover backwards and lift off.
Use a T8 Torx Security screwdriver to remove the five screws.
Two 31mm screws.
Three 10mm screws.
Remove the metal plate.
Flip the console to its back once again.
Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
Use a T8 Torx security screwdriver to remove the two 10mm silver screws from the metal plate.
Flip the console over to continue working on the top side.
Place fingers underneath edge of power supply unit on both sides and pull straight up.
Grip the connector behind the power supply and pull straight out.
27 weitere Nutzer haben diese Anleitung absolviert.
7 Kommentare
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
