Einleitung
Use this guide to remove or replace your Playstation 4 Slim’s plastic bottom cover.
Was du brauchst
Locate the plastic warranty sticker next to the three ports on the side of the console.
Remove the warranty sticker by peeling it off with any kind of spudger.
Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
Pry up on the two corners that are facing you with your fingers.
Remove the bottom cover by sliding it towards the back corners and lifting up.
36 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Wo kann man die Bodenplatte kaufen?
Hi hello it's Good
