Einleitung
This is a fairly simple repair that most people should be able complete with no problems.
*You are using this guide at your own risk. TronicsFix take no responsibility and will not be held liable for any damages that may occur while using this guide.
Was du brauchst
Unplug PS4 from all cables
Remove hard drive cover
Remove two Torx T8 security screws from top cover.
Remove warranty sticker (if it's still there) and remove black screw for the top case using Torx T8 security screw.
Pull up on front right edge of top cover.
After right front is loose pull up on left front.
Pull top cover back and set aside.
Using a Phillips PH1, remove two APU/heat sink clamp screws.
Start by installing 2 washers under each screw.
Install the clamp and screws and tighten screws.
Plug power cord into PS4.
Touch copper pad on PS4 to power on.
If PS4 powers on and stays on consider it fixed. If not, proceed to next step.
If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
After third washer has been installed and the screws have been tightened touch the power pad on the motherboard.
If the PS4 makes no noise and shows no lights then the screws are too tight...loosen screws very slightly (about 1/8 turn) and try to power it on again. Do this until the console powers on.
If the console still turns on and back off after these steps have been done then this fix will not work for your PS4.
If your PS4 will not turn on (or turns on and right back off) after you have already had it working, try taking the cover back off and tighten the screws on the plate. If the screws are too tight the PS4 will not work at all. Slightly loosen until the system turns on. Be cautious about having the console plugged in. Possible but not recommended.
If you have your whole cover off of your PS4, and it is working properly, be sure to replace the cover. The cover is designed to distribute air from the fan and keep the system cool. It will cause it to turn off on its own if over heated.
56 weitere Nutzer:innen haben diese Anleitung absolviert.
49 Kommentare
Can't believe it worked! My PS4 has been sitting useless for so long and I felt to good when I did this today and it seemed completely normal again. We'll see if this works out over time or if it starts doing the same thing again. One thing I don't get is why they don't specify the washer size you'll need if you don't want to buy the entire kit, but I guess that's just marketing. Thus, I tore squares of glossy paper (a picture I had laying around) and poked them into the nails instead of washers. Works just as well for me!
What size washers are needed for this
has this fixed your system permanently? did you have any problems since your last post?
worked for me!
and it will for a few day/weeks at most then it will fail again
