Zum Hauptinhalt wechseln
PlayStation 5 Pro CMOS Board Replacement
Was du brauchst
  1. PlayStation 5 Pro CMOS Board Replacement, Before you begin: Schritt 1, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Before you begin: Schritt 1, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Before you begin: Schritt 1, Bild 3 von 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. PlayStation 5 Pro CMOS Board Replacement, Remove the console covers: Schritt 2, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the console covers: Schritt 2, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the console covers: Schritt 2, Bild 3 von 3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. PlayStation 5 Pro CMOS Board Replacement: Schritt 3, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement: Schritt 3, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement: Schritt 3, Bild 3 von 3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. PlayStation 5 Pro CMOS Board Replacement, Remove the expansion slot cover screw: Schritt 4, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Remove the expansion slot cover screw: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  5. PlayStation 5 Pro CMOS Board Replacement, Remove the expansion slot cover: Schritt 5, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the expansion slot cover: Schritt 5, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the expansion slot cover: Schritt 5, Bild 3 von 3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  6. PlayStation 5 Pro CMOS Board Replacement, Remove the fan cables cover: Schritt 6, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the fan cables cover: Schritt 6, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the fan cables cover: Schritt 6, Bild 3 von 3
    Tesa 61395 Tape
    $8.95
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  7. PlayStation 5 Pro CMOS Board Replacement, Free the fan cables: Schritt 7, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Free the fan cables: Schritt 7, Bild 2 von 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  8. PlayStation 5 Pro CMOS Board Replacement, Disconnect the fan: Schritt 8, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Disconnect the fan: Schritt 8, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Disconnect the fan: Schritt 8, Bild 3 von 3
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  9. PlayStation 5 Pro CMOS Board Replacement, Remove the fan screws: Schritt 9, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Remove the fan screws: Schritt 9, Bild 2 von 2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
  10. PlayStation 5 Pro CMOS Board Replacement, Remove the fan: Schritt 10, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Remove the fan: Schritt 10, Bild 2 von 2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  11. PlayStation 5 Pro CMOS Board Replacement, Peel up the tamper evident sticker: Schritt 11, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Peel up the tamper evident sticker: Schritt 11, Bild 2 von 2
  12. PlayStation 5 Pro CMOS Board Replacement, Remove the fan grille: Schritt 12, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the fan grille: Schritt 12, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the fan grille: Schritt 12, Bild 3 von 3
    • Use your fingers to unclip and remove the plastic grille near the fan recess.
  13. PlayStation 5 Pro CMOS Board Replacement, Remove the right‑side inner shell screws: Schritt 13, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Remove the right‑side inner shell screws: Schritt 13, Bild 2 von 2
    • Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
    • Four 18.8 mm‑long screws
    • Two 18.6 mm‑long screws
    • Four 31.7 mm‑long screws
  14. PlayStation 5 Pro CMOS Board Replacement, Remove the right‑side inner shell: Schritt 14, Bild 1 von 2 PlayStation 5 Pro CMOS Board Replacement, Remove the right‑side inner shell: Schritt 14, Bild 2 von 2
    • Lift the right‑side inner shell straight up and remove it.
  15. PlayStation 5 Pro CMOS Board Replacement, Disconnect the CMOS board: Schritt 15, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Disconnect the CMOS board: Schritt 15, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Disconnect the CMOS board: Schritt 15, Bild 3 von 3
    • Use a pair of angled tweezers to firmly grip the sides of the CMOS board connector, holding the tweezers as close to the connector as possible to get a good grip.
    • Pull the connector straight up and out of its socket to disconnect it.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
  16. PlayStation 5 Pro CMOS Board Replacement, Remove the CMOS board: Schritt 16, Bild 1 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the CMOS board: Schritt 16, Bild 2 von 3 PlayStation 5 Pro CMOS Board Replacement, Remove the CMOS board: Schritt 16, Bild 3 von 3
    • Use your fingers to lift the CMOS board off the small metal nubs and pull it toward the center of your console to remove it.
    • If your new board doesn't come with a cable, transfer the original cable to your replacement board.
Abschluss
Spencer Day
183.794 Reputation
1.166 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
25.563 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 73
Insgesamt: 698
