Zum Hauptinhalt wechseln
PlayStation Move Battery Replacement
Was du brauchst
  1. PlayStation Move Battery Replacement, Case: Schritt 1, Bild 1 von 2 PlayStation Move Battery Replacement, Case: Schritt 1, Bild 2 von 2
    • Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
  2. PlayStation Move Battery Replacement: Schritt 2, Bild 1 von 3 PlayStation Move Battery Replacement: Schritt 2, Bild 2 von 3 PlayStation Move Battery Replacement: Schritt 2, Bild 3 von 3
    • Pinch the sides of the back panel to remove it and set it aside.
  3. PlayStation Move Battery Replacement: Schritt 3, Bild 1 von 2 PlayStation Move Battery Replacement: Schritt 3, Bild 2 von 2
    • Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
  4. PlayStation Move Battery Replacement: Schritt 4, Bild 1 von 2 PlayStation Move Battery Replacement: Schritt 4, Bild 2 von 2
    • Push the Lithium Ion battery from its slot to remove it.
    • Be mindful not to damage the wires or wired components, as the battery will still be attached via its connector.
  5. PlayStation Move Battery Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the 9mm screw in the battery slot with a PH #00 screwdriver.
  6. PlayStation Move Battery Replacement: Schritt 6, Bild 1 von 2 PlayStation Move Battery Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, carefully pry the rumble motor free.
  7. PlayStation Move Battery Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the 9mm screw behind the rumble motor slot with a PH #00 screwdriver.
  8. PlayStation Move Battery Replacement: Schritt 8, Bild 1 von 3 PlayStation Move Battery Replacement: Schritt 8, Bild 2 von 3 PlayStation Move Battery Replacement: Schritt 8, Bild 3 von 3
    • Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
  9. PlayStation Move Battery Replacement: Schritt 9, Bild 1 von 2 PlayStation Move Battery Replacement: Schritt 9, Bild 2 von 2
    • Using your fingers, carefully pry the square green piece beneath the battery slot free.
    • It is attached via white ribbons which need to be kept intact.
  10. PlayStation Move Battery Replacement: Schritt 10, Bild 1 von 3 PlayStation Move Battery Replacement: Schritt 10, Bild 2 von 3 PlayStation Move Battery Replacement: Schritt 10, Bild 3 von 3
    • Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
    • Lift the rectangular piece from its slot to free it.
  11. PlayStation Move Battery Replacement: Schritt 11, Bild 1 von 3 PlayStation Move Battery Replacement: Schritt 11, Bild 2 von 3 PlayStation Move Battery Replacement: Schritt 11, Bild 3 von 3
    • Carefully lift the entire circuit board from the black plastic encasing it.
    • Take extra care not to damage any of the wired components.
  12. PlayStation Move Battery Replacement, Battery: Schritt 12, Bild 1 von 2 PlayStation Move Battery Replacement, Battery: Schritt 12, Bild 2 von 2
    • Using tweezers, carefully pull the power cable from its port on the circuit board.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Sarah Shand
1.885 Reputation
7 Anleitungen geschrieben
USF Tampa, Team S3-G1, Sullivan Spring 2017 Mitglied von USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
No need to remove the the rumble motor, if you are careful and gentle and have some good tweezers you can unplug the battery cable after step 4, but it’s safer to do all steps
Andrew S. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 38
Letzte 30 Tage: 198
Insgesamt: 20,480
