Einleitung
This is a prerequisite guide that will show you how to disassemble the PlayStation Move controller.
Was du brauchst
Turn the controller over and unscrew the four 10mm screws with a PH #00 screwdriver.
Hold the base of the controller with one hand and with the other carefully pull up on the white spherical piece to remove it.
Carefully pinch the plastic sides of the battery slot and lift it (along with the circuit board) from the plastic shell of the move controller.
Using your fingers, carefully pry the square green piece beneath the battery slot free.
Follow the white ribbon attached to the part you just removed to a smaller, more rectangular piece.
Lift the rectangular piece from its slot to free it.
