Einleitung
Use this guide to replace the LED light on the Playstation Move
Was du brauchst
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
Remove the five 1.2 mm screws from upper portion of the controller.
Cautiously remove the circular white piece at the top without removing the LED inside.
Remove the blue strip that is connected to the trigger button from the motherboard.
Insert tweezers between the LED case and the LED clear plastic cover.
Lift the edge of the LED clear cover clip to be able to remove the cover.
Repeat the previous step to the other side.
Remove the LED cover.
Remove the LED board using a blue opening tool to lift the board.
After the board is loose, remove the LED board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Okay, going to try this. Do I have to solder the white strip back onto the board?
did you ever get this done? need to know the same.
