Zum Hauptinhalt wechseln
PlayStation Move Motherboard Replacement
Was du brauchst
  1. PlayStation Move Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 PlayStation Move Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 PlayStation Move Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
  2. PlayStation Move Motherboard Replacement: Schritt 2, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
  3. PlayStation Move Motherboard Replacement: Schritt 3, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  4. PlayStation Move Motherboard Replacement: Schritt 4, Bild 1 von 3 PlayStation Move Motherboard Replacement: Schritt 4, Bild 2 von 3 PlayStation Move Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  5. PlayStation Move Motherboard Replacement: Schritt 5, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  6. PlayStation Move Motherboard Replacement: Schritt 6, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  7. PlayStation Move Motherboard Replacement: Schritt 7, Bild 1 von 3 PlayStation Move Motherboard Replacement: Schritt 7, Bild 2 von 3 PlayStation Move Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  8. PlayStation Move Motherboard Replacement: Schritt 8, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Gently pull on the white piece connecting the battery and the connector.
  9. PlayStation Move Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 3 PlayStation Move Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 3 PlayStation Move Motherboard Replacement, Motherboard: Schritt 9, Bild 3 von 3
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
  10. PlayStation Move Motherboard Replacement: Schritt 10, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the two 1.2mm Phillips #1 screws.
  11. PlayStation Move Motherboard Replacement: Schritt 11, Bild 1 von 3 PlayStation Move Motherboard Replacement: Schritt 11, Bild 2 von 3 PlayStation Move Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Cautiously remove the circular white piece at the top without removing the LED inside.
  12. PlayStation Move Motherboard Replacement: Schritt 12, Bild 1 von 3 PlayStation Move Motherboard Replacement: Schritt 12, Bild 2 von 3 PlayStation Move Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
  13. PlayStation Move Motherboard Replacement: Schritt 13, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the trigger button from the controller.
  14. PlayStation Move Motherboard Replacement: Schritt 14, Bild 1 von 3 PlayStation Move Motherboard Replacement: Schritt 14, Bild 2 von 3 PlayStation Move Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
  15. PlayStation Move Motherboard Replacement: Schritt 15, Bild 1 von 2 PlayStation Move Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Remove the motherboard from the plastic case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 3-3, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
Where does one obtain a replacement motherboard?
Tekkromancer - Antwort
my controllers are also dying anyone know where to get a replacement board? I live in Canada
Jin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 1,566
