Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove all cables plugged into the PlayStation.
    • Remove all cables plugged into the PlayStation.
  2. Flip over the PlayStation and remove the six screws from the bottom. Flip over the PlayStation and remove the six screws from the bottom.
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. Laptop-Akkus
    Akkus für die wichtigsten Laptop-Marken, abgesichert über unsere Qualitäts-Garantie.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  4. Flip the PlayStation back.
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  5. Lift up and remove the upper case. Lift up and remove the upper case.
    • Lift up and remove the upper case.
  6. Disconnect the ribbon cable and wired cable connectors. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy. Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
    • Disconnect the ribbon cable and wired cable connectors.
    • Take extreme care when disconnecting ribbon cable from motherboard. Tears extremely easy.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
trickster
1.968 Reputation
11 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 3,503
