Was du brauchst
Remove the parallel port cover on the back of the PlayStation
Carefully disconnect the gold-colored ribbon cable from it's connector.
To avoid damaging the cable, pull it by the white, reinforced tab.
Remove the two screws and take off the bottom piece for your new Optical drive from the old one.
Take the new lens either from a SCPH-7501 or SCPH-9001.
To avoid damaging the cable, Gently lift on this gold-colored cable that has a pot screw on it and lift it, but not too much.
Plug the cables back in. Your work should look like this. Put it back together, plug it in, turn it on and see if it works.
