Zum Hauptinhalt wechseln
PlayStation VR Band Adjuster Replacement
Was du brauchst
  1. PlayStation VR Band Adjuster Replacement, Band Adjuster: Schritt 1, Bild 1 von 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: Schritt 1, Bild 2 von 3 PlayStation VR Band Adjuster Replacement, Band Adjuster: Schritt 1, Bild 3 von 3
    • Use your hands to remove the foam piece in the headband.
    • Use the iFixIt Opening Tool to pry the top and bottom trim pieces off of the rear band assembly.
  2. PlayStation VR Band Adjuster Replacement: Schritt 2, Bild 1 von 1
    • Remove a total of four 5 mm screws from inside the left and right sides of the headband using a Phillips #00 screwdriver.
  3. PlayStation VR Band Adjuster Replacement: Schritt 3, Bild 1 von 2 PlayStation VR Band Adjuster Replacement: Schritt 3, Bild 2 von 2
    • Remove three silver 5 mm screws that are securing the rear white cover of the band using a Phillips #00 screwdriver.
  4. PlayStation VR Band Adjuster Replacement: Schritt 4, Bild 1 von 3 PlayStation VR Band Adjuster Replacement: Schritt 4, Bild 2 von 3 PlayStation VR Band Adjuster Replacement: Schritt 4, Bild 3 von 3
    • Remove the 6 mm screw from the retainer securing wires to the rear band assembly using a Phillips #00 screwdriver.
    • Use a spudger to flip up the retaining flap connected to the rear LEDs.
  5. PlayStation VR Band Adjuster Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 5 mm screw from the center of the headband adjuster using a Phillips #00 screwdriver.
  6. PlayStation VR Band Adjuster Replacement: Schritt 6, Bild 1 von 1
    • Gently pry the adjuster assembly away from the rear headband using an opening tool.
  7. PlayStation VR Band Adjuster Replacement: Schritt 7, Bild 1 von 3 PlayStation VR Band Adjuster Replacement: Schritt 7, Bild 2 von 3 PlayStation VR Band Adjuster Replacement: Schritt 7, Bild 3 von 3
    • Disassemble the adjuster assembly spring, small gear, large gear, and bracket in order to replace the broken component.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 69
Insgesamt: 2,460
