Einleitung
This guide shows you how to disassemble and replace the microphone on your Playstation VR headset.
Was du brauchst
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
Use the plastic opening tool to pry the top white plastic panel free from the headset.
Flip the headset over.
Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
Carefully pull the end of the white ribbon connector from its slot.
Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
Remove the yellow LED ribbons and black plastic connecting piece from the headset.
Pinch the small white cable connector and unplug it from the motherboard.
The microphone will be attached to the white cable connector on the bottom right of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
