Einleitung
This guide applies to the CUH-ZVR2 processor unit.
Was du brauchst
Place the PlayStation VR processor unit with the I/O (back) side facing up.
Peel the sticker up with a fingernail or a pry tool.
Remove the single J0 screw.
Place the screw in a parts tray to keep it organized.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the eight J0 screws.
Use your tweezers to disconnect the fan connector from the motherboard
Brand: Nidec
Model and dimensions: U35x05m 52aa7-56j14
Power: 5v and .18a
Use a spudger or a fingernail to lift the pcb in the direction highlighted
Gently separate the metal plate from pcb
Replace the thermal paste if needed.
Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
4 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
