Einleitung
This guide applies to the CUH-ZVR2 processor unit.
Was du brauchst
Place the PlayStation VR processor unit with the I/O (back) side facing up.
Peel the sticker up with a fingernail or a pry tool.
Remove the single J0 screw.
Place the screw in a parts tray to keep it organized.
Remove the eight J0 screws.
Use your tweezers to disconnect the fan connector from the motherboard
Brand: Nidec
Model and dimensions: U35x05m 52aa7-56j14
Power: 5v and .18a
Use a spudger or a fingernail to lift the pcb in the direction highlighted
Gently separate the metal plate from pcb
Replace the thermal paste if needed.
Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
