Zum Hauptinhalt wechseln
PlayStation Vita Speakers Replacement
Was du brauchst
  1. PlayStation Vita Speakers Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita Speakers Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Speakers Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita Speakers Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita Speakers Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Speakers Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita Speakers Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Speakers Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita Speakers Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita Speakers Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Speakers Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita Speakers Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Speakers Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Speakers Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Speakers Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita Speakers Replacement, Speakers: Schritt 9, Bild 1 von 2 PlayStation Vita Speakers Replacement, Speakers: Schritt 9, Bild 2 von 2
    • Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
    • The speaker is adhered to the casing with light tape, which may give the speaker light resistance.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brittany McCrigler
89.011 Reputation
131 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.731 Anleitungen geschrieben
2 Kommentare
My Ps vita is still not playing sound with the volume all the way up. Think this could be electrical?
Sarah - Antwort
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
Luis Hernández - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 108
Insgesamt: 12,166
