Zum Hauptinhalt wechseln
PlayStation scph-1001 Eye replacement
Was du brauchst
  1. PlayStation scph-1001 Eye replacement, Eye: Schritt 1, Bild 1 von 2 PlayStation scph-1001 Eye replacement, Eye: Schritt 1, Bild 2 von 2
    • This is your PlayStation before you do this teardown.
  2. PlayStation scph-1001 Eye replacement: Schritt 2, Bild 1 von 1
    • Now take the 5 black screws out of the case.
  3. PlayStation scph-1001 Eye replacement: Schritt 3, Bild 1 von 2 PlayStation scph-1001 Eye replacement: Schritt 3, Bild 2 von 2
    • Now flip the system back over to its top. 'Be sure not to drop the top when you pick it up.
  4. PlayStation scph-1001 Eye replacement: Schritt 4, Bild 1 von 2 PlayStation scph-1001 Eye replacement: Schritt 4, Bild 2 von 2
    • Pick up on the top case after you have flipped it over. This will have a little resistance but this should not break anything if you have all of the five screws out of the under case.
  5. PlayStation scph-1001 Eye replacement: Schritt 5, Bild 1 von 1
    • Then undo the piece holding in the ribbon cable. When you do this grab the side of the black piece holding it in place and pick it up slowly
  6. PlayStation scph-1001 Eye replacement: Schritt 6, Bild 1 von 2 PlayStation scph-1001 Eye replacement: Schritt 6, Bild 2 von 2
    • Then undo the power cable and the eye Cable these should just lift right off.
  7. PlayStation scph-1001 Eye replacement: Schritt 7, Bild 1 von 2 PlayStation scph-1001 Eye replacement: Schritt 7, Bild 2 von 2
    • Now just pick up on the eye and set it off to the side the reassembly
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Is this guide compatible with scph-1002 as well?
Markus Norstrøm - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 54
Letzte 30 Tage: 239
Insgesamt: 4,965
