Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Archiviert
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Archiviert
Einleitung
Power supplies take electricity from a wall socket and convert it so that it may be used by the various components of the PS3.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the rubber screw cover near the hard drive cover with a spudger. Remove the rubber screw cover near the hard drive cover with a spudger.
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Remove the screw holding the top cover in place with a Torx T10 screwdriver.
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Slide the top cover down about half an inch. Lift the cover off of the PS3.
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Remove the seven screws in the top cover with a Phillips #2 screwdriver. One of the screws is shorter than the others. The short screw is marked in yellow.
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  6. You can now lift off the top cover. You can now lift off the top cover. You can now lift off the top cover.
    • You can now lift off the top cover.
  7. Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back. Push down the tab on the connector to disconnect the wires.
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  8. Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  9. Remove the power supply by lifting it straight up. Remove the power supply by lifting it straight up.
    • Remove the power supply by lifting it straight up.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,478
