Einleitung
The function of a XLR cable is to carry a balanced audio signal. It connects in the bottom of the microphone to the XLR microphone connector.
Make sure you have a proper three pin XLR cable.
Grab the female end of the cable (plug with three holes).
Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
To disconnect the cable from the microphone, follow the instructions in reverse.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
21 Kommentare
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
do it in reverse? you have to press the button though on the male end...
