Einleitung
You will be using a metal spudger for this guide to remove the back cover. This is a prerequisite step for all further guides and will be important for all replacement steps. It is advised to be cautious when using the tools to avoid further damage to the equipment.
Was du brauchst
Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
Use a metal spudger to begin lifting the back cover.
Then, create leverage and gently remove the entire cover.
