Zum Hauptinhalt wechseln
Plum Optimax 10 Headphone Jack Replacement
Was du brauchst
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: Schritt 1, Bild 1 von 2 Plum Optimax 10 Headphone Jack  Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: Schritt 2, Bild 1 von 2 Plum Optimax 10 Headphone Jack  Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: Schritt 3, Bild 1 von 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: Schritt 3, Bild 2 von 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: Schritt 3, Bild 3 von 3
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 82
