Zum Hauptinhalt wechseln
Plumbing replace Brita water filters with a better solution Replacement
  1. Plumbing replace Brita water filters with a better solution Replacement, find cold water supply to faucet: Schritt 1, Bild 1 von 1
    • Cold water is the supply line is on the right. Turn it off before starting.
  2. Plumbing replace Brita water filters with a better solution Replacement, Parts needed less than $100: Schritt 2, Bild 1 von 1
    • Pentek 10" filter and slimline housing
    • 3/8 compression supply line and 3/8 faucet supply line
    • Filter wrench
    • 3/8" compression to 3/8" pipe thread fittings (two), 3/8"close nipple, and 3/8" female elbow (if needed). Total less than
  3. Plumbing replace Brita water filters with a better solution Replacement, Assemble and install: Schritt 3, Bild 1 von 1
    • use teflon tape on male threads when assembling. do not overtighten.
    • Enjoy filtered water for less than a penny a gallon.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 383
