Zum Hauptinhalt wechseln
Pneumatic Door Closer Replacement
Was du brauchst
  1. Pneumatic Door Closer Replacement, Pneumatic Door Closer: Schritt 1, Bild 1 von 2 Pneumatic Door Closer Replacement, Pneumatic Door Closer: Schritt 1, Bild 2 von 2
    • Identify the broken part of the door.
  2. Pneumatic Door Closer Replacement: Schritt 2, Bild 1 von 2 Pneumatic Door Closer Replacement: Schritt 2, Bild 2 von 2
    • Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
  3. Pneumatic Door Closer Replacement: Schritt 3, Bild 1 von 3 Pneumatic Door Closer Replacement: Schritt 3, Bild 2 von 3 Pneumatic Door Closer Replacement: Schritt 3, Bild 3 von 3
    • Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
  4. Pneumatic Door Closer Replacement: Schritt 4, Bild 1 von 2 Pneumatic Door Closer Replacement: Schritt 4, Bild 2 von 2
    • Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
  5. Pneumatic Door Closer Replacement: Schritt 5, Bild 1 von 3 Pneumatic Door Closer Replacement: Schritt 5, Bild 2 von 3 Pneumatic Door Closer Replacement: Schritt 5, Bild 3 von 3
    • Plug the smallest included screw into the inner bracket to attach the door closer.
  6. Pneumatic Door Closer Replacement: Schritt 6, Bild 1 von 3 Pneumatic Door Closer Replacement: Schritt 6, Bild 2 von 3 Pneumatic Door Closer Replacement: Schritt 6, Bild 3 von 3
    • Close the door.
    • Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
  7. Pneumatic Door Closer Replacement: Schritt 7, Bild 1 von 3 Pneumatic Door Closer Replacement: Schritt 7, Bild 2 von 3 Pneumatic Door Closer Replacement: Schritt 7, Bild 3 von 3
    • Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
  8. Pneumatic Door Closer Replacement: Schritt 8, Bild 1 von 2 Pneumatic Door Closer Replacement: Schritt 8, Bild 2 von 2
    • Make sure the door closes and opens properly.
    • Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
Ziellinie
Abdullah Kaddura
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 631
