Einleitung
Do you have a door that just doesn’t seem to want to close? Your screen or storm door constantly being left open because the little cylinder up there at the top just isn’t working how it used to? Well if you follow this short guide you will be able to save yourself grey hairs and daily annoyances.
Some call it a “Door Closer” or “Pneumatic door closing cylinder”
There are several reasons why your door might not be closing, a bent cylinder, twisted or incorrectly placed brackets. We will be addressing the last two of these issues in this guide.
Was du brauchst
Remove the old piston from its current position.
Pull out two pins—one on both sides of the piston.
Unpack your new brackets and piston.
Be sure to lay out all the parts to ensure that you have an accurate inventory of all parts.
Once marked, use a cordless drill with a Philips #2 bit to drive the four 1 1/2" screws into the bracket into the trim.
Using the two pins that were previously removed, secure the piston to the brackets.
You have now fixed your door and saved your future self countless frustrations and gray hairs!
