Zum Hauptinhalt wechseln
Pocket Knife Wooden Casing Replacement
Was du brauchst
  1. Pocket Knife Wooden Casing Replacement, Wooden Casing: Schritt 1, Bild 1 von 2 Pocket Knife Wooden Casing Replacement, Wooden Casing: Schritt 1, Bild 2 von 2
    • Trace the knife outline onto wood.
    Frag FixBot
    Kommentar hinzufügen
  2. Pocket Knife Wooden Casing Replacement: Schritt 2, Bild 1 von 2 Pocket Knife Wooden Casing Replacement: Schritt 2, Bild 2 von 2
    • Cut out the outline of the wood.
    • Cut the height of the wood to the correct measurement.
    Frag FixBot
  3. Pocket Knife Wooden Casing Replacement: Schritt 3, Bild 1 von 2 Pocket Knife Wooden Casing Replacement: Schritt 3, Bild 2 von 2
    • Sand the wood so that it is smooth and free of hard edges.
    • For the best result, sand in the direction of the grain as much as possible.
    Frag FixBot
  4. Pocket Knife Wooden Casing Replacement: Schritt 4, Bild 1 von 3 Pocket Knife Wooden Casing Replacement: Schritt 4, Bild 2 von 3 Pocket Knife Wooden Casing Replacement: Schritt 4, Bild 3 von 3
    • Stain and polish the wood so that it is reflects the other side of the knife.
    • Apply another coat after the first coat dries if you want a darker stain.
    • If you get the Stain and Polish on your skin, your skin might be stained for a few days. In this case, make sure you wash thoroughly; Stain and Polish is only toxic if it is ingested.
    Frag FixBot
  5. Pocket Knife Wooden Casing Replacement: Schritt 5, Bild 1 von 2 Pocket Knife Wooden Casing Replacement: Schritt 5, Bild 2 von 2
    • Drill four small holes that will go over the extruded parts of the knife.
    • You can accurately mark the positions of the holes by coloring the screw heads with sharpie then stamping them into the wood.
    Frag FixBot
  6. Pocket Knife Wooden Casing Replacement: Schritt 6, Bild 1 von 3 Pocket Knife Wooden Casing Replacement: Schritt 6, Bild 2 von 3 Pocket Knife Wooden Casing Replacement: Schritt 6, Bild 3 von 3
    • Glue the wood to the knife and clean any hard edges or excess glue that comes from this step.
    Frag FixBot
Ziellinie
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 834
