Zum Hauptinhalt wechseln
Poin2 Chromebook 11 Battery Replacement
Was du brauchst
  1. Poin2 Chromebook 11 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Poin2 Chromebook 11 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Battery Replacement: Schritt 2, Bild 1 von 3 Poin2 Chromebook 11 Battery Replacement: Schritt 2, Bild 2 von 3 Poin2 Chromebook 11 Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Battery Replacement: Schritt 3, Bild 1 von 3 Poin2 Chromebook 11 Battery Replacement: Schritt 3, Bild 2 von 3 Poin2 Chromebook 11 Battery Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Battery Replacement: Schritt 4, Bild 1 von 2 Poin2 Chromebook 11 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery from the frame.
Abschluss
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
Henry Covey
237 Reputation
2 Anleitungen geschrieben
Ein Kommentar
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
Marty Sharik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 935
