Einleitung
This guide shows how to replace a defective battery from a Poin2 Chromebook 11, remove the battery to test the device's power adapter, or remove the battery in order to access another component.
Was du brauchst
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Insert a 1cm-wide plastic opening tool between the base and top frame.
Pry (up and down) around the entire border of the Chromebook to separate.
Use your hands to gently lift the base away from the frame.
Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
To reassemble your Poin2 Chromebook 11, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
An important piece of information missing is the battery replacement number.
a Google search brings up no references.
