Einleitung
When a Chromebook is plugged into an outlet with a working adapter, but the device will neither charge or power on, this is a sign that the charging port is damaged and needs to be replaced. This guide shows how to replace a defective charging port for a Poin2 Chromebook 11.
Was du brauchst
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Insert a 1cm-wide plastic opening tool between the base and top frame.
Pry (up and down) around the entire border of the Chromebook to separate.
Use your hands to gently lift the base away from the frame.
Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
Use tweezers to gently pull the charging port out of the frame.
4 weitere Personen haben diese Anleitung absolviert.
