Einleitung
This guide shows how to replace the speakers of the Poin2 Chromebook 11.
Was du brauchst
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Insert a 1cm-wide plastic opening tool between the base and top frame.
Pry (up and down) around the entire border of the Chromebook to separate.
Use your hands to gently lift the base away from the frame.
Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
Unplug the black speaker cable from the lower, left side of the motherboard.
Detach the speaker cord from the hooks holding it to the frame and lift the speakers away.
