Zum Hauptinhalt wechseln
Pokewalker Battery Replacement
Was du brauchst
  1. Pokewalker Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the Rear Cover from the Device
  4. Pokewalker Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the flat end of a Spudger to Remove the Battery
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Winni Stuart
417 Reputation
2 Anleitungen geschrieben
2 Kommentare
The battery must be placed positive side facing up if I am correct.
I just dug my pokewalker out of my closet. Been years since it has been used. Putting in an effort to get it running again.
Thanks for the tutorial.
Jake Allen - Antwort
I just got my Pokéwalker up and running again as well. Nintendo's stuff is always so well made.
signature -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 125
Letzte 30 Tage: 551
Insgesamt: 25,487
