Zum Hauptinhalt wechseln
Pokewalker Button Replacement
Was du brauchst
  1. Pokewalker Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the Rear Cover from the Device
  4. Pokewalker Button Replacement: Schritt 4, Bild 1 von 1
    • Use the flat end of a Spudger to Remove the Battery
    • Locate the 4 Screws Around the Device
    • Remove all 4 screws with a Y0 Triwing Screwdriver
    • Separate the 2 halves of the Device
    • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
  5. In diesem Schritt verwendetes Werkzeug:
    • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
    • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
    • Remove the Rubber-button thingy from the upper case
    • I have no idea what that thing is, edit this guide if you do.
    • Remove the 3 Plastic Buttons from the Case
    • It helps that the buttons only go in one way, makes it easier to reassemble
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 67
Insgesamt: 1,078
