Zum Hauptinhalt wechseln
Polar M400 Watch Screen Replacement
Was du brauchst
  1. Polar M400 Watch Screen Replacement, Wrist Strap: Schritt 1, Bild 1 von 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Screen Replacement: Schritt 2, Bild 1 von 2 Polar M400 Watch Screen Replacement: Schritt 2, Bild 2 von 2
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: Schritt 3, Bild 1 von 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: Schritt 5, Bild 1 von 2 Polar M400 Watch Screen Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: Schritt 6, Bild 1 von 2 Polar M400 Watch Screen Replacement: Schritt 6, Bild 2 von 2
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
  7. Polar M400 Watch Screen Replacement, Screen: Schritt 7, Bild 1 von 2 Polar M400 Watch Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: Schritt 8, Bild 1 von 2 Polar M400 Watch Screen Replacement: Schritt 8, Bild 2 von 2
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Maine, Team S1-G3, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G3, Diaz Fall 2017
UMAINE-DIAZ-F17S1G3
4 Mitglieder
7 Anleitungen geschrieben
10 Kommentare
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - Antwort
hi,where can I buy the usb replacement.
GamesFISH_1989 - Antwort
Hi, were can i buy the replacement. Thanks
Julien Genon - Antwort
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - Antwort
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 54
Insgesamt: 9,000
