Zum Hauptinhalt wechseln
Diese Übersetzung wurde maschinell erstellt und noch nicht von einer Person überprüft. Sprichst du diese Sprache? Schau es dir an.
Polar V800 Barometer/Altimeter Replacement
Was du brauchst
    1. Polar V800 Barometer/Altimeter Replacement, Waterproofing Seal: Schritt 1, Bild 1 von 2 Polar V800 Barometer/Altimeter Replacement, Waterproofing Seal: Schritt 1, Bild 2 von 2
      • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
      • Ensure your Polar V800 sports watch is powered off before continuing.
      • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Polar V800 Barometer/Altimeter Replacement: Schritt 2, Bild 1 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 2, Bild 2 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 2, Bild 3 von 3
      • Gently separate the watch housing from the back panel.
      • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
      Frag FixBot
    3. Polar V800 Barometer/Altimeter Replacement: Schritt 3, Bild 1 von 2 Polar V800 Barometer/Altimeter Replacement: Schritt 3, Bild 2 von 2
      • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
      • Remove the waterproofing seal.
      • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
      Frag FixBot
    1. Polar V800 Barometer/Altimeter Replacement, Motherboard: Schritt 4, Bild 1 von 3 Polar V800 Barometer/Altimeter Replacement, Motherboard: Schritt 4, Bild 2 von 3 Polar V800 Barometer/Altimeter Replacement, Motherboard: Schritt 4, Bild 3 von 3
      • Though not necessary, following the Polar V800 Display austauschen first may make the motherboard easier to remove.
      • Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
      Frag FixBot
    2. Polar V800 Barometer/Altimeter Replacement: Schritt 5, Bild 1 von 1
      • Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
      • A red wire and a black wire should run between the motherboard and the battery.
      Frag FixBot
    3. Polar V800 Barometer/Altimeter Replacement: Schritt 6, Bild 1 von 1
      • The battery is glued down to the back of the watch. It may take some force to detach the battery at the glue joint.
      • Use a spudger to pry the battery from the back of the watch.
      • If your battery is swollen, be very careful in removing the battery. If the packaging is ruptured, the battery will be unsafe to handle with bare hands. The contents of the battery are hazardous.
      Frag FixBot
    4. Polar V800 Barometer/Altimeter Replacement: Schritt 7, Bild 1 von 1
      • Gently pull the wires from their solder joints to disconnect them from the body of the watch.
      • If the wires do not come off easily, you may need to desolder the connections. Visit Wie man Lötverbindungen herstellt und entlötet for more help on soldering.
      • To reconnect the wires to their solder joints, they must be soldered on. See the guide linked above for more guidance.
      Frag FixBot
    1. Polar V800 Barometer/Altimeter Replacement, Barometer disassembly: Schritt 8, Bild 1 von 1
      • The barometer is visible inside the red circle on the photo
      Frag FixBot
    2. Polar V800 Barometer/Altimeter Replacement: Schritt 9, Bild 1 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 9, Bild 2 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 9, Bild 3 von 3
      • Using a small flathead screwdriver or pliers, remove the red seal around the barometric sensor.
      • The sensor is strongly glued and welded on the mother board. Beware of the micro components positioned nearby, avoid taking support on them when removing the seal.
      • Unsolder or cut short the black/red wires soldered on the casing.
      Frag FixBot
    3. Polar V800 Barometer/Altimeter Replacement: Schritt 10, Bild 1 von 1
      • A blue dot allows the good position/orientation of the component. Take note of the position of this dot prior removing the faulty component.
      • Component ref MS580502BA01-50
      Frag FixBot
    4. Polar V800 Barometer/Altimeter Replacement: Schritt 11, Bild 1 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 11, Bild 2 von 3 Polar V800 Barometer/Altimeter Replacement: Schritt 11, Bild 3 von 3
      • With a 350°C soldering iron and a desoldering wick remove as much solder as possible. Then try to remove the component with angled pliers
      • It is likely that the component is glued to the board. In this case, the only solution that I've found was to remove the component by cutting it piece by piece with mini flush cutters.
      • The target is to get a surface where to put the new component as clean as possible, while keeping the soldering pads and without destroying nearby components. That is the most complex operation.
      Frag FixBot
    5. Polar V800 Barometer/Altimeter Replacement: Schritt 12, Bild 1 von 1
      • Put a VERY SMALL drop of glue (no superglue, use a glue that solidifies slower like epoxy so that you can correct misplacement of the component if it does not align with the solder pads) in the component placement area and put it in there (take care to place the component so that the blue dot is at the right position!)
      • Solder the 4 contacts with a thin tip soldering iron. The use of flux will make the operation easier.
      Frag FixBot
Abschluss
Follow instruction in reverse order to assemble the device. Do not forget to resolder the black/red wires to the casing.
fr en
100%
Hier starten ›
Alexandre Moulart
163 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 48
Insgesamt: 1,150
