Zum Hauptinhalt wechseln
Polar V800 Charging Port Cover Replacement
Was du brauchst
  1. Polar V800 Charging Port Cover Replacement, Watch Band: Schritt 1, Bild 1 von 3 Polar V800 Charging Port Cover Replacement, Watch Band: Schritt 1, Bild 2 von 3 Polar V800 Charging Port Cover Replacement, Watch Band: Schritt 1, Bild 3 von 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: Schritt 2, Bild 1 von 3 Polar V800 Charging Port Cover Replacement: Schritt 2, Bild 2 von 3 Polar V800 Charging Port Cover Replacement: Schritt 2, Bild 3 von 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: Schritt 3, Bild 1 von 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: Schritt 3, Bild 2 von 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: Schritt 3, Bild 3 von 3
    • Take off the charging port cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nick B.
387 Reputation
1 Anleitung geschrieben
Cal Poly, Team S17-G6, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
where does not procure the battery port cover ?
Chenthill P - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 2,929
