Einleitung
This guide will show users how to replace the display (not the glass screen) on the Polar V800 sports watch. If the display has damaged pixels or no longer operates properly, the display may need to be replaced to keep your watch functional.
Was du brauchst
Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
Lift the display from the board from the top side of the watch, revealing the display connectors underneath.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, gently pull the display wiring out of the two connectors that attach the display to the motherboard.
4 weitere Personen haben diese Anleitung absolviert.
15 Kommentare zur Anleitung
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Por sin la encontré. Lleva una Sharp LS013B7DH03
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
Same question as above.
