Zum Hauptinhalt wechseln
Polar V800 Motherboard Replacement
Was du brauchst
    1. Polar V800 Motherboard Replacement, Waterproofing Seal: Schritt 1, Bild 1 von 2 Polar V800 Motherboard Replacement, Waterproofing Seal: Schritt 1, Bild 2 von 2
      • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
      • Ensure your Polar V800 sports watch is powered off before continuing.
      • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Polar V800 Motherboard Replacement: Schritt 2, Bild 1 von 3 Polar V800 Motherboard Replacement: Schritt 2, Bild 2 von 3 Polar V800 Motherboard Replacement: Schritt 2, Bild 3 von 3
      • Gently separate the watch housing from the back panel.
      • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
      Frag FixBot
    3. Polar V800 Motherboard Replacement: Schritt 3, Bild 1 von 2 Polar V800 Motherboard Replacement: Schritt 3, Bild 2 von 2
      • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
      • Remove the waterproofing seal.
      • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
      Frag FixBot
    1. Polar V800 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 Polar V800 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 Polar V800 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
      • Though not necessary, following the Polar V800 Display austauschen first may make the motherboard easier to remove.
      • Remove the nine, 4.0 millimeter-long screws with a T5 head-type torque screwdriver.
      Frag FixBot
    2. Polar V800 Motherboard Replacement: Schritt 5, Bild 1 von 1
      • Once all of the screws have been removed, lift the motherboard to expose the battery beneath motherboard.
      • A red wire and a black wire should run between the motherboard and the battery.
      Frag FixBot
    3. Polar V800 Motherboard Replacement: Schritt 6, Bild 1 von 1
      • The battery is glued down to the back of the watch. It may take some force to detach the battery at the glue joint.
      • Use a spudger to pry the battery from the back of the watch.
      • If your battery is swollen, be very careful in removing the battery. If the packaging is ruptured, the battery will be unsafe to handle with bare hands. The contents of the battery are hazardous.
      Frag FixBot
    4. Polar V800 Motherboard Replacement: Schritt 7, Bild 1 von 1
      • Gently pull the wires from their solder joints to disconnect them from the body of the watch.
      • If the wires do not come off easily, you may need to desolder the connections. Visit Wie man Lötverbindungen herstellt und entlötet for more help on soldering.
      • To reconnect the wires to their solder joints, they must be soldered on. See the guide linked above for more guidance.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S17-G6, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Mitglieder
72 Anleitungen geschrieben
2 Kommentare zur Anleitung
Where can the replacement motherboard be bought? Thanks
Randall - Antwort Teilen
Bonjour et merci pour ses photos ezt explication, mais savez vous ou commander le joint rouge entourant et faisant l “ étanchéité de celle ci. Merci
facebook - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 31
Insgesamt: 2,196
