Einleitung
The viewfinder is the square piece on top of the camera that houses a square glass eye that you look through to see what you are taking a photo of.
Was du brauchst
Use a Phillips #0 screwdriver to remove the two 20 mm screws on the back of the viewfinder.
Remove the back cover of the viewfinder.
Push out the lens that is flush with the back of the viewfinder cover.
Fast fertig!
Abschluss
