Einleitung
The bellows are the part of the camera that may be made of a material that is shiny and looks like the fluid part of an accordion.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
