Zum Hauptinhalt wechseln
Polaroid Automatic 100 Bellows Replacement
Was du brauchst
  1. Polaroid Automatic 100 Bellows Replacement, Bellows: Schritt 1, Bild 1 von 3 Polaroid Automatic 100 Bellows Replacement, Bellows: Schritt 1, Bild 2 von 3 Polaroid Automatic 100 Bellows Replacement, Bellows: Schritt 1, Bild 3 von 3
    • Fully extend the bellows by lifting the #1 lever.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bellows Replacement: Schritt 2, Bild 1 von 1
    • Peel the two battery cable tabs off of the bellows.
  3. Polaroid Automatic 100 Bellows Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
    • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
    • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
    • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
  4. Polaroid Automatic 100 Bellows Replacement: Schritt 4, Bild 1 von 2 Polaroid Automatic 100 Bellows Replacement: Schritt 4, Bild 2 von 2
    • Open the back cover by pushing the lever on the bottom towards the left.
  5. Polaroid Automatic 100 Bellows Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
    • To make the screws easily accessible, close the bellows by pushing on the metal frame.
    • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
  6. Polaroid Automatic 100 Bellows Replacement: Schritt 6, Bild 1 von 1
    • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
  7. Polaroid Automatic 100 Bellows Replacement: Schritt 7, Bild 1 von 2 Polaroid Automatic 100 Bellows Replacement: Schritt 7, Bild 2 von 2
    • Pull the bellow tabs back with long needle nose pliers.
    • Remove the bellows.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Katie Miller
680 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-3, Maness Spring 2015 Mitglied von Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 2,051
