Zum Hauptinhalt wechseln
Polaroid Automatic 100 Bottom Frame Spring Replacement
Was du brauchst
  1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: Schritt 1, Bild 1 von 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: Schritt 1, Bild 2 von 3 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: Schritt 1, Bild 3 von 3
    • Fully extend the bellows to prevent collapse using the #1 tab.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bottom Frame Spring Replacement: Schritt 2, Bild 1 von 1
    • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
  3. Polaroid Automatic 100 Bottom Frame Spring Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
  4. Polaroid Automatic 100 Bottom Frame Spring Replacement: Schritt 4, Bild 1 von 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: Schritt 4, Bild 2 von 3 Polaroid Automatic 100 Bottom Frame Spring Replacement: Schritt 4, Bild 3 von 3
    • Remove the spring from the shutter mount.
    • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
    • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Katie Miller
680 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-3, Maness Spring 2015 Mitglied von Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare zur Anleitung
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - Antwort
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 1,264
