Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The spread roll spring is a vital part of the polaroid that ensures that your developing photo will exit the camera once your photo is taken.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Push the lever on the bottom of the camera towards the left. Open the rear door of the camera.
    • Push the lever on the bottom of the camera towards the left.
    • Open the rear door of the camera.
  2. Unlatch the red clip on the side. Lift the rollers up. Position the camera with the back cover closest to you.
    • Unlatch the red clip on the side.
    • Lift the rollers up.
    • Position the camera with the back cover closest to you.
  3. Remove the rear roll by using the plastic opening tool to take it off the metal frame. Then remove the front roll by pushing away from you with the plastic opening tool. Then remove the front roll by pushing away from you with the plastic opening tool.
    • Remove the rear roll by using the plastic opening tool to take it off the metal frame.
    • Then remove the front roll by pushing away from you with the plastic opening tool.
  4. Unscrew the three 2.5 mm screws (attached to the metal plate) with a 3.0 flathead screwdriver. Then take off the metal plate.
    • Unscrew the three 2.5 mm screws (attached to the metal plate) with a 3.0 flathead screwdriver. Then take off the metal plate.
  5. Pull the support rod out.
    • Pull the support rod out.
Abschluss
Katie Miller
650 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-3, Maness Spring 2015 Mitglied von Cal Poly, Team 4-3, Maness Spring 2015
CPSU-MANESS-S15S4G3
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 485
