Einleitung
This guide provides a great explanation about how to replace the lens of the Polaroid cube.
Due to the thickness and width of the screws, make sure to carefully remove them using a screwdriver and a magnet pad.
Was du brauchst
Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
Use the Plastic Opening Tool to pry open the shell of the camera.
There are four latches, one at each corner, that you will need to detach.
Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
Use the plastic opening tool to remove the circuit board that the battery is connected to.
Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
