Einleitung
This guide will walk you through the video quality switch on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
Was du brauchst
Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
Use the Plastic Opening Tool to pry open the shell of the camera.
There are four latches, one at each corner, that you will need to detach.
Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
Use the plastic opening tool to remove the circuit board that the battery is connected to.
Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
Remove and replace the broken video quality switch.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
