Zum Hauptinhalt wechseln
Polaroid Now Gen 3 Battery Replacement
Was du brauchst
  1. Polaroid Now Gen 3 Battery Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Polaroid Now Gen 3 Battery Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Before you begin:
    • Unplug and fully power down your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
    Frag FixBot
    Kommentar hinzufügen
  2. Polaroid Now Gen 3 Battery Replacement, Open the film door: Schritt 2, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Open the film door: Schritt 2, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Open the film door: Schritt 2, Bild 3 von 3
    • Throughout this guide, directional words (front, back, left, right) are from the perspective of using the camera—or when the lens faces away from you.
    • Hold down the latch on the left side of the camera and open the film door.
    Frag FixBot
  3. Polaroid Now Gen 3 Battery Replacement, Remove the rear shell screw: Schritt 3, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Remove the rear shell screw: Schritt 3, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Remove the rear shell screw: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the 5.9 mm‑long screw securing the rear shell.
    • The screw is hidden inside the camera on the back edge—you may need to use a flashlight to see it, as well as a skinny, long‑shank screwdriver to reach it.
    • Be careful when removing your screwdriver, as the screw can easily fall inside the camera. If it does, hold the camera above your work surface and gently shake it so the screw falls out.
    Frag FixBot
  4. Polaroid Now Gen 3 Battery Replacement, Release the rear shell clips: Schritt 4, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Release the rear shell clips: Schritt 4, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Release the rear shell clips: Schritt 4, Bild 3 von 3
    • Insert the flat edge of an opening pick in the seam between the front and rear shells, just above the USB‑C port on the right edge.
    • Use your pick to pry the rear shell away from the front shell.
    • Keep the inserted edge of the pick pointed toward the rear shell when separating it. This helps release the tight plastic clips holding them together.
    Frag FixBot
  5. Polaroid Now Gen 3 Battery Replacement: Schritt 5, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 5, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 5, Bild 3 von 3
    • You should feel and hear distinct "clicks" as the clips release. If you don't, try again—it may take multiple attempts.
    • Slide your pick around the top right corner and along the top edge to release the clips.
    Frag FixBot
  6. Polaroid Now Gen 3 Battery Replacement: Schritt 6, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 6, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 6, Bild 3 von 3
    • Continue sliding your pick along the top edge, around the top left corner, and down the left edge to release the clips. Stop when you get to the film door latch.
    Frag FixBot
  7. Polaroid Now Gen 3 Battery Replacement: Schritt 7, Bild 1 von 1
    • Gently flip the camera over, making sure none of the clips re‑engage.
    Frag FixBot
  8. Polaroid Now Gen 3 Battery Replacement: Schritt 8, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 8, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement: Schritt 8, Bild 3 von 3
    • Remember to keep the inserted edge of the pick pointed towards the rear shell.
    • Insert your opening pick in the seam near the USB‑C port and slide it around the corner and along the bottom edge to release the remaining clips.
    Frag FixBot
  9. Polaroid Now Gen 3 Battery Replacement, Camera mirror warning: Schritt 9, Bild 1 von 2 Polaroid Now Gen 3 Battery Replacement, Camera mirror warning: Schritt 9, Bild 2 von 2
    • Removing the rear shell in the next step exposes the camera mirror. Be careful not to smudge it or get any debris on it. If you accidentally do, use a lint‑free cloth to gently wipe the mirror clean.
    Frag FixBot
  10. Polaroid Now Gen 3 Battery Replacement, Remove the rear shell: Schritt 10, Bild 1 von 2 Polaroid Now Gen 3 Battery Replacement, Remove the rear shell: Schritt 10, Bild 2 von 2
    • Gently pull the rear shell off the main body of the camera.
    • The shell should slide off easily. If it doesn't, check to see if any clips re‑engaged and use your opening pick to release them.
    • During reassembly:
    • Press the shell firmly onto the main body so all the clips engage.
    • You should feel and hear distinct "clicks" as the clips engage.
    • Check around the shell seam and make sure there are no gaps. If there are, firmly press the shells together to engage the clip near the gap.
    Frag FixBot
  11. Polaroid Now Gen 3 Battery Replacement, Capacitor warning: Schritt 11, Bild 1 von 2 Polaroid Now Gen 3 Battery Replacement, Capacitor warning: Schritt 11, Bild 2 von 2
    • The capacitor in your camera holds an electrical charge and can deliver a potentially dangerous electric shock if you touch the boards incorrectly.
    • To minimize risk, avoid touching the boards, wires, and other exposed components with your fingers or metal tools. Consider wearing rubber gloves if working near the board.
    Frag FixBot
  12. Polaroid Now Gen 3 Battery Replacement, Reposition the battery tape: Schritt 12, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Reposition the battery tape: Schritt 12, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Reposition the battery tape: Schritt 12, Bild 3 von 3
    • Use your fingers to remove the piece of tape securing the battery and its cables (just below the viewfinder).
    • Put the piece of tape aside—you'll use it during reassembly.
    Frag FixBot
  13. Polaroid Now Gen 3 Battery Replacement, Disconnect the sub‑board cable: Schritt 13, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Disconnect the sub‑board cable: Schritt 13, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Disconnect the sub‑board cable: Schritt 13, Bild 3 von 3
    • Disconnecting the sub‑board cable makes battery removal easier and prevents accidentally damaging the cable or its delicate connector.
    • Use a spudger to flip up the hinged locking flap on the sub board ZIF connector.
    • Use a pair of tweezers or your fingers to gently pull the cable straight out of its socket.
    Frag FixBot
  14. Polaroid Now Gen 3 Battery Replacement, Reposition the battery: Schritt 14, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Reposition the battery: Schritt 14, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Reposition the battery: Schritt 14, Bild 3 von 3
    • Gently slide the battery out of its plastic housing.
    • Don't try to fully remove the battery yet, as it's still connected by a delicate cable.
    Frag FixBot
  15. Polaroid Now Gen 3 Battery Replacement, Remove the battery: Schritt 15, Bild 1 von 3 Polaroid Now Gen 3 Battery Replacement, Remove the battery: Schritt 15, Bild 2 von 3 Polaroid Now Gen 3 Battery Replacement, Remove the battery: Schritt 15, Bild 3 von 3
    • Firmly grip the larger end of the plastic battery connector with one hand and the battery's cable in the other—grip the battery cable as close to the connector as possible.
    • Pull the battery cable straight away from the connector to disconnect it.
    • Be very careful not to strain the cables.
    • Remove the battery.
    Frag FixBot
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
189.369 Reputation
1.190 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.843 Anleitungen geschrieben
1 Kommentar zur Anleitung
The case can be very difficult to remove, I found I also needed to use the end of the tweezers to force it open. It takes some effort.
Also this is for the Gen 3, not Gen 1. Unfortunately there's no guide for Gen 1 on this site. For the Gen 1, the battery is much more difficult to remove. You'll need to remove the door and the front plate as well. There's a really helpful video on YouTube which will go through this from Analog Studio for the Polaroid Now.
Struan M - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 67
Insgesamt: 850
