Zum Hauptinhalt wechseln
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: Schritt 1, Bild 1 von 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: Schritt 1, Bild 2 von 3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: Schritt 1, Bild 3 von 3
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: Schritt 2, Bild 1 von 1
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: Schritt 3, Bild 1 von 1
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
Ziellinie
14 weitere Personen haben diese Anleitung absolviert.
Doug Jimenez
556 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 16-31, Maness Winter 2010 Mitglied von Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Mitglieder
9 Anleitungen geschrieben
15 Kommentare zur Anleitung
It worked but its expensive
Jessica diaz - Antwort Teilen
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - Antwort Teilen
nothing happened
new film installed
no sound
no flash
no action
eminickstone - Antwort Teilen
I'm having the same issue
Marie - Teilen
I'm having same issue.
Marie - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 74
Letzte 30 Tage: 256
Insgesamt: 157,558
