Einleitung
This guide will show how to remove the face plate, which is necessary to exposing the internal components.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Begin by opening the top of the camera (flash assembly) to a slight angle.
Next, angle the flash assembly slightly upward and pry off the connections carefully.
Slide the action button, on the bottom of the camera, to open the bottom.
Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
Pull off the face plate.
Fast fertig!
Abschluss
