Zum Hauptinhalt wechseln
Polaroid Onestep Close Up Primary Lens Replacement
Was du brauchst
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: Schritt 1, Bild 1 von 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: Schritt 1, Bild 2 von 3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: Schritt 1, Bild 3 von 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: Schritt 2, Bild 1 von 2 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: Schritt 2, Bild 2 von 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: Schritt 3, Bild 1 von 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: Schritt 3, Bild 2 von 3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: Schritt 3, Bild 3 von 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: Schritt 4, Bild 1 von 1
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: Schritt 5, Bild 1 von 2 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: Schritt 5, Bild 2 von 2
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 3-5, Brown Fall 2014 Mitglied von USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,554
