Zum Hauptinhalt wechseln
Polaroid Onestep Close Up Rear Viewfinder Replacement
Was du brauchst
  1. Polaroid Onestep Close Up Rear Viewfinder Replacement, Flash Assembly Removal: Schritt 1, Bild 1 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Flash Assembly Removal: Schritt 1, Bild 2 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Flash Assembly Removal: Schritt 1, Bild 3 von 3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Rear Viewfinder Replacement, Opening Film Tray: Schritt 2, Bild 1 von 2 Polaroid Onestep Close Up Rear Viewfinder Replacement, Opening Film Tray: Schritt 2, Bild 2 von 2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Rear Viewfinder Replacement, Removing Face Plate: Schritt 3, Bild 1 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Removing Face Plate: Schritt 3, Bild 2 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Removing Face Plate: Schritt 3, Bild 3 von 3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Rear Viewfinder Replacement, Core Assembly Removal: Schritt 4, Bild 1 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Core Assembly Removal: Schritt 4, Bild 2 von 3 Polaroid Onestep Close Up Rear Viewfinder Replacement, Core Assembly Removal: Schritt 4, Bild 3 von 3
    • To remove the rear casing, use a spudger to leverage the sides of the metal frame at the bottom loose. If the spudger is in danger of breaking, it is safe to use a screwdriver.
    • With that, the entire inner assembly should be separated from the rear casing. Carefully remove it.
    • During reassembly, when re-inserting the core assembly into the plastic casing, remember not to let the small red wire (visible in the third image) catch onto the small black hook on the casing (green)! The wire must be held down so as not to be hooked.
  5. Polaroid Onestep Close Up Rear Viewfinder Replacement, Removal of rear viewfinder assembly: Schritt 5, Bild 1 von 2 Polaroid Onestep Close Up Rear Viewfinder Replacement, Removal of rear viewfinder assembly: Schritt 5, Bild 2 von 2
    • Once the rear casing is removed, lower the flash. The rear viewfinder lens assembly is located on the left side of the camera, when looking at it from the rear.
    • Simply wiggle the assembly loose.
  6. Polaroid Onestep Close Up Rear Viewfinder Replacement, Removal of rear viewfinder lens: Schritt 6, Bild 1 von 1
    • You may decide to stop here and replace the assembly altogether. However, you may otherwise decide to separate the lens from the plastic enclosure.
    • In this case, there is a notch that is part of the lens shape (green) that fits into a matching groove in the enclosure (red). You will need to employ leverage to push the lens notch in and down while pulling the wall of the enclosure up in order to remove the lens.
    • WARNING: Removing the lens by exerting force on both it and the enclosure is very likely to break the fragile enclosure to some degree. The tolerances are very tight and the enclosure is reinforced in many different locations that may make the lens removal extremely difficult. Be very careful and think twice before attempting to remove the lens.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 3-5, Brown Fall 2014 Mitglied von USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 1,655
