Zum Hauptinhalt wechseln
Polaroid P902 Charging Port Replacement
Was du brauchst
  1. Polaroid P902 Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 1
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
  2. Polaroid P902 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
  3. Polaroid P902 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
  4. Polaroid P902 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
  5. Polaroid P902 Charging Port Replacement: Schritt 5, Bild 1 von 3 Polaroid P902 Charging Port Replacement: Schritt 5, Bild 2 von 3 Polaroid P902 Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Using a soldering iron, desolder the points circled on the picture until the solder has liquefied enough to be able to remove the wires from the circuit board.
    • When using the soldering iron, be careful not to cause damage to the motherboard.
  6. Polaroid P902 Charging Port Replacement: Schritt 6, Bild 1 von 2 Polaroid P902 Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder.
  7. Polaroid P902 Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Using tweezers, remove the charging port from the circuit board.
    • This should be done quickly as the solder will begin to solidify.
Abschluss
Trent Moskwinski
145 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G2, Harley Spring 2018 Mitglied von IUPUI, Team S2-G2, Harley Spring 2018
IUPUI-HARLEY-S18S2G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 721
