Zum Hauptinhalt wechseln
Polaroid S10 Battery Replacement
Was du brauchst
  1. Polaroid S10 Battery Replacement, Removing the backcover: Schritt 1, Bild 1 von 3 Polaroid S10 Battery Replacement, Removing the backcover: Schritt 1, Bild 2 von 3 Polaroid S10 Battery Replacement, Removing the backcover: Schritt 1, Bild 3 von 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Polaroid S10 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Polaroid S10 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: Schritt 3, Bild 1 von 2 Polaroid S10 Battery Replacement, Battery Connection: Schritt 3, Bild 2 von 2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Abschluss
Follow these instructions to reassemble your device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
James
367 Reputation
3 Anleitungen geschrieben
Colorado Springs, Team 1-4, May Spring 2015 Mitglied von Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
4 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 5,157
