Zum Hauptinhalt wechseln
Polaroid S10 Speaker Replacement
Was du brauchst
  1. Polaroid S10 Speaker Replacement, Removing the backcover: Schritt 1, Bild 1 von 3 Polaroid S10 Speaker Replacement, Removing the backcover: Schritt 1, Bild 2 von 3 Polaroid S10 Speaker Replacement, Removing the backcover: Schritt 1, Bild 3 von 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Speaker Replacement, Speaker Assembly: Schritt 2, Bild 1 von 2 Polaroid S10 Speaker Replacement, Speaker Assembly: Schritt 2, Bild 2 von 2
    • Use a heavy-duty nylon spudger to remove the tape.
    • Unscrew the four 5 mm screws with the J000 screwdriver that connects the speakers.
  3. Polaroid S10 Speaker Replacement, Desoldering the Speakers: Schritt 3, Bild 1 von 2 Polaroid S10 Speaker Replacement, Desoldering the Speakers: Schritt 3, Bild 2 von 2
    • Carefully desolder the 4 connections of the speakers.
    • Do not touch the soldering iron to the motherboard or LCD screen.
Abschluss
James
367 Reputation
3 Anleitungen geschrieben
Colorado Springs, Team 1-4, May Spring 2015 Mitglied von Colorado Springs, Team 1-4, May Spring 2015
UCCS-MAY-S15S1G4
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 346
